本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace or upgrade your optical drive...or both!
你所需要的
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
Remove the two 3.7 mm T6 Torx screws securing the optical drive connector board to the optical drive.
8等其他人完成本指南。
