跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
    • Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
  2. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  3. Pull the optical drive up by its white pull tab to disconnect it from the logic board. Lift the free end of the optical drive just enough to clear the fan cover.  Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel.
    • Pull the optical drive up by its white pull tab to disconnect it from the logic board.
    • Lift the free end of the optical drive just enough to clear the fan cover. Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel.
    • Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
    • Lift the optical drive out of your iMac.
    • When reinstalling your optical drive it may be necessary to set the bezel attached to the open end of the drive on the plastic positioning pins molded into the front bezel of the iMac and pull the connector side of the drive toward the edge of the rear case, bending it outward slightly, to properly seat the connector.
结论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 628
