跳转到主内容
加入维修社区 - 创建账户
iMac G5 20" Model A1076 Midplane Assembly Replacement
你所需要的
    1. iMac G5 20" Model A1076 Midplane Assembly Replacement, Rear Panel: 步骤 1 中的图像 1,1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      添加评论
    2. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 2 中的图像 1,2 iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 2 中的图像 2,2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      询问修复机器人
      添加评论
    1. iMac G5 20" Model A1076 Midplane Assembly Replacement, RAM: 步骤 3 中的图像 1,2 iMac G5 20" Model A1076 Midplane Assembly Replacement, RAM: 步骤 3 中的图像 2,2
      • Rotate each of the two RAM retaining arms away from the RAM chip.
      • The chip will partially pop out at the same time as the arms are pulled out to either side.
      • Pull the RAM chip straight away from its socket.
      • Repeat this process for the other RAM chip.
      • Be sure the RAM arms are rotated fully outward before installing new RAM chips.
      询问修复机器人
      添加评论
    1. iMac G5 20" Model A1076 Midplane Assembly Replacement, Inverter: 步骤 4 中的图像 1,1
      • Remove the following three screws securing the inverter to the chassis:
      • Two 7.9 mm Phillips.
      • One 26 mm Phillips.
      • When reinstalling the inverter, be careful to route the purple and black cables around the screw mount. It is very easy to pinch the cable and damage the insulation.
      询问修复机器人
      添加评论
    2. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 5 中的图像 1,2 iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 5 中的图像 2,2
      • Slide the inverter toward the edge of the mid-plane, then lift it out of the iMac.
      • Be careful to not pry up against the RAM brackets.
      • When reinstalling the inverter, press the blue and white cables down in the edge of the midplane before lowering the inverter down into the midplane. The black cable can be routed near the hard drive thermal sensor cable.
      询问修复机器人
      添加评论
    3. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 6 中的图像 1,1
      • Disconnect the large inverter cable connector from the inverter by pulling straight away from its socket.
      询问修复机器人
      添加评论
    4. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 7 中的图像 1,1
      • Disconnect the small inverter cable connector by pulling it straight away from its socket.
      询问修复机器人
      添加评论
    5. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 8 中的图像 1,1
      • Disconnect the hard drive thermal sensor cable from the thermal sensor board on the hard drive bracket by pulling the cable away from the heat sink.
      询问修复机器人
      添加评论
    6. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 9 中的图像 1,1
      • Gently pull the black inverter cable to disconnect it from the logic board.
      • If you have trouble plugging this cable back in during reinstallation, remove the fan duct for more room to work.
      询问修复机器人
      添加评论
    7. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 10 中的图像 1,1
      • Flip up the inverter cable cover from its left edge and lift it out of the chassis.
      询问修复机器人
      添加评论
    8. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 11 中的图像 1,1
      • De-route the inverter cables from the inverter cable cover hook.
      询问修复机器人
      添加评论
    9. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 12 中的图像 1,3 iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 12 中的图像 2,3 iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 12 中的图像 3,3
      • Remove the inverter cables from the inverter cable cover, and disconnect both connectors.
      询问修复机器人
      添加评论
    10. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 13 中的图像 1,2 iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 13 中的图像 2,2
      • If you wish to replace just the inverter board, use a spudger to pry off its plastic cover.
      询问修复机器人
      添加评论
    1. iMac G5 20" Model A1076 Midplane Assembly Replacement, Optical Drive: 步骤 14 中的图像 1,1
      • Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
      询问修复机器人
      添加评论
    2. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 15 中的图像 1,2 iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 15 中的图像 2,2
      • Pull the optical drive up by its white pull tab to disconnect it from the logic board.
      • Lift the free end of the optical drive just enough to clear the fan cover. Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel.
      • Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
      • Lift the optical drive out of your iMac.
      • When reinstalling your optical drive it may be necessary to set the bezel attached to the open end of the drive on the plastic positioning pins molded into the front bezel of the iMac and pull the connector side of the drive toward the edge of the rear case, bending it outward slightly, to properly seat the connector.
      询问修复机器人
      添加评论
    1. iMac G5 20" Model A1076 Midplane Assembly Replacement, Midplane Assembly: 步骤 16 中的图像 1,1
      • Remove the two 7.3 mm shouldered Phillips screws securing the display cable connector to the logic board.
      询问修复机器人
      添加评论
    2. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 17 中的图像 1,2 iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 17 中的图像 2,2
      • Pull the display data cable up off the logic board by its black pull tab.
      • De-route the display cable from the two aluminum fingers in the mid-plane.
      询问修复机器人
      添加评论
    3. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 18 中的图像 1,1
      • Loosen the center Phillips screw securing the power supply to the front case.
      • This screw will remain captive in the power supply.
      询问修复机器人
      添加评论
    4. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 19 中的图像 1,1
      • Remove the four coarse-thread 7.8 mm Phillips screws along the top edge of the iMac.
      询问修复机器人
      添加评论
    5. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 20 中的图像 1,1
      • Remove the following two screws:
      • One 7 mm Phillips.
      询问修复机器人
      添加评论
    6. iMac G5 20" Model A1076 Midplane Assembly Replacement: 步骤 21 中的图像 1,1
      • Lift the midplane assembly out of the front case.
      • Be mindful of the inverter cables on the hard drive sie of the midplane that may get caught as you lift out the midplane.
      • During reinstallation, insert the screw heads protruding from the speakers along the lower edge of the midplane into the holes in the front bezel and thread the inverter cables through the openings in the midplane before lowering the top edge down into the front bezel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
John
于11/02/10注册
372 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 28
总计 5,019
