跳转到主内容
加入维修社区 - 创建账户
iMac G5 20" Model A1076 Bluetooth board Replacement
你所需要的
    1. iMac G5 20" Model A1076 Bluetooth board Replacement, Rear Panel: 步骤 1 中的图像 1,1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      添加评论
    2. iMac G5 20" Model A1076 Bluetooth board Replacement: 步骤 2 中的图像 1,2 iMac G5 20" Model A1076 Bluetooth board Replacement: 步骤 2 中的图像 2,2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      询问修复机器人
      添加评论
    1. iMac G5 20" Model A1076 Bluetooth board Replacement, Bluetooth board: 步骤 3 中的图像 1,1
      • Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
      询问修复机器人
      添加评论
    2. iMac G5 20" Model A1076 Bluetooth board Replacement: 步骤 4 中的图像 1,2 iMac G5 20" Model A1076 Bluetooth board Replacement: 步骤 4 中的图像 2,2
      • Bend a paper clip into a hook and use it to pull the Bluetooth board up off its socket on the logic board.
      询问修复机器人
      添加评论
    3. iMac G5 20" Model A1076 Bluetooth board Replacement: 步骤 5 中的图像 1,1
      • Use a spudger to pry the Bluetooth antenna connector up off the Bluetooth board.
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
1指南评论
Greetings Walter Galan, I would like to know if I can install this iMac G5 20" Model A1076 Bluetooth board into my iMac 21 system, it say’s that no wireless is installed.
Please Advise!
Thank You In Advance & Have A Good One!!!.
R.Askew
Randy Askew - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 58
总计 10,761
