你所需要的
Remove the T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board.
Remove the flex cable mounting bracket.
Disconnect the optical drive thermal sensor.
Alternatively unstick the sensor from the drive, and leave it connected to the cable.
Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
I think the 10-year-old jab at "Apple’s ‘Engineers’” is pretty bad taste and unnecessary. Someone made a mistake. Nobody sat around at a board meeting drooling stupidly and saying “euyh we shudl just put stickbar in plastic make latch difficult to open euhh”. So I opt to remove the 15-year-old-kid level commentary from the beginning of this step to clean it up :)
Remove the two T10 Torx screws from the side of the optical drive.
Removal of these screws can wait until the entire bracket assembly is out of the chassis. Remove the screws when you remove the bracket from the drive, step 23.
Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
2等其他人完成本指南。
