本指南有最近更改,您可查看未经巡查的最新版本。
简介
Keep processor temperatures down by replacing your broken fans.
你所需要的
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
另外一个人完成了本指南。
