跳转到主内容
iMac G5 17" Model A1058 RAM Replacement
你所需要的
  1. iMac G5 17" Model A1058 RAM Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 RAM Replacement: 步骤 2 中的图像 1,3 iMac G5 17" Model A1058 RAM Replacement: 步骤 2 中的图像 2,3 iMac G5 17" Model A1058 RAM Replacement: 步骤 2 中的图像 3,3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 RAM Replacement, RAM: 步骤 3 中的图像 1,3 iMac G5 17" Model A1058 RAM Replacement, RAM: 步骤 3 中的图像 2,3 iMac G5 17" Model A1058 RAM Replacement, RAM: 步骤 3 中的图像 3,3
    • Rotate each of the two RAM retaining arms away from the RAM chip.
    • Pull the RAM chip straight away from its socket.
    • Repeat this process for the other RAM chip.
    • Be sure the RAM arms are fully rotated away from the RAM socket before reinstalling any RAM chips.
结论
39等其他人完成本指南。
4条评论
Way too easy. Doubled my RAM in 5 minutes. Computer runs like new again.
Darren Fox - 回复
Can i get 6 or 8 gigs ram?
frederikchalmer - 回复
Do both the ram slots have to have ram in them
Gary Wayne - 回复
When I cut it on the Apple pops up then a colored screen comes up with horizontal lines
Gary Wayne - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 27
总计 30,369
