当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
Push the spudger away from the AirPort card to disconnect the AirPort antenna.
When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
Do not bend the metal retaining clip up, as it is brittle and will break.
Use another spudger to slide the PRAM battery out from under its socket's retaining clip.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
