本指南有最近更改,您可查看未经巡查的最新版本。
简介
Like brain surgery? Use this guide to replace your logic board.
你所需要的
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor board.
61等其他人完成本指南。
