简介
Like brain surgery? Use this guide to replace your logic board.
你所需要的
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Grab the power supply from each side and rotate its top edge toward yourself until it clears the logic board.
Lift the power supply out of the midplane.
Bend the case at the rear panel clamp enough to clear the panel clamp while lifting out the power supply using the two captive screws as handles.
Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor board.
Remove the two 13 mm T10 Torx screws securing the fan duct to the midplane.
Lift the fan duct out of the midplane.
The screws are T10, not T8
来自 Yishai Sered 的话:
Mine are T10.
Insert the tip of a spudger into the center hole punched into the side of the lower fan connector.
With the spudger still inserted, lift the lower fan connector straight up off the logic board.
Grab the logic board from both edges and lift it out of the midplane, minding any cables that may get caught.
There is a white support foot under the board directly behind the speaker. If this comes free with the board, it should be placed on the frame using the locating plastic nipples before replacing the board. Do not attach it to the board and try to push it back down as there is in sufficient space for it to pass through.
61等其他人完成本指南。
My iMac has only ONE catch, the central one, so the two outer screws are not to be touched.
In fact, I tried so hard to unscrew them, with a good screwdriver, that my hand hurt. Knowing that some times captive things (like these screws or a faucet) can be already at the end of their travel and we only lock them further into that position, I tried both screwing and unscrewing to no avail.
paulfrancoeur - 回复
The two outer screws each drive a locking bar that engage tabs on the rear panel.
They definitely need to be unscrewed.
Dale Stanbrough -
That chick MJ is sexy!!!!!
djmadcracker - 回复
Looks like one of these screws is not like the others... a security Philips?! Never seen one of those before.
Terry Mullane - 回复
Please Note: If your iMac has an antenna for the airport extreme and not the bluetooth card. Don't buy the bluetooth get the airport extreme instead. Also, some newer devices may not work with these units.
James Janota - 回复
Just want to say thank you to ifixit! You guys are amazing and so helpful! This was so easy to do and I ordered the part I needed as well! We are up and running over here and my 7 year old son could not be any happier! Thank you!
mary nicolazzo - 回复
These are the easiest way to resolve the Wireless connectivity at my home. Thanks ifixit for sharing this.
Geek Squad - 回复
