本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove your display inverter.
你所需要的
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the three 8 mm brass Phillips screws securing the optical drive to the midplane.
Slide the inverter-to-display cable connector from under the metal clip on the midplane.
即将完成!
结论
