跳转到主内容
iMac G5 17" Model A1058 AirPort Extreme Replacement
你所需要的
  1. iMac G5 17" Model A1058 AirPort Extreme Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 AirPort Extreme Replacement: 步骤 2 中的图像 1,3 iMac G5 17" Model A1058 AirPort Extreme Replacement: 步骤 2 中的图像 2,3 iMac G5 17" Model A1058 AirPort Extreme Replacement: 步骤 2 中的图像 3,3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 AirPort Extreme Replacement, AirPort Extreme: 步骤 3 中的图像 1,1
    • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
    • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
  4. iMac G5 17" Model A1058 AirPort Extreme Replacement: 步骤 4 中的图像 1,1
    • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
    • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
    • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
结论
23等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 31,822
