跳转到主内容
iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement
你所需要的
  1. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate: 步骤 1 中的图像 1,1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 步骤 2 中的图像 1,1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: 步骤 4 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Bottom Plate Housing: 步骤 4 中的图像 2,2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 步骤 5 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 步骤 5 中的图像 2,2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement, Logic Board Assembly: 步骤 6 中的图像 1,1
    • Gently remove the cables marked in red.
  7. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the three metal 10mm T-15 screws.
    • Remove the one nylon 10mm T-15 screw.
  8. iMac G4 17 800 MHz EMC 1936 Logic Board Assembly Replacement: 步骤 8 中的图像 1,1
    • Using thumbs and forefingers, firmly grasp the battery holder in one hand while grasping the metal bar in the other. Gently lift and pull the logic board to release it.
    i followed instructions and the logic board is stuck in there! can’t find any answers on the web either. any ideas?
    the biohazard - 回复
结论
9等其他人完成本指南。
Justin
于10/05/11注册
303 声望
创作了3篇指南
团队
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G22
4 名成员
创作了13篇指南
一条评论
We need to say what cables to remove in step 6 of Logic Board Assembly
Courtney - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 48
总计 10,520
