当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
The next cord to unplug between the two panels of the display is the inverter cable. This will be located under the inverter closer to the bottom of the screen and will have only two cables connecting at a smaller white connection.
Like the inverter cable, grasp each side of the white connection and gently unplug the inverter cable.
这个步骤还没有翻译 帮忙翻译一下
The third, and final, cable you will need to unplug is the TMDS connector. This is located under a rectangular strip of black tape that has a gray and black cord coming out of one end.
Peel back the black tape, starting at the end with the cords protruding out.
Under the black tape, you will see the gray and black cords going into a connection that looks like it is wrapped in aluminum foil. Grasp that connection and pull carefully in the downward direction toward the bottom of the display.
8等其他人完成本指南。
3条评论
For every step we need to have an action. Step 4 of dissasembling the screen does not have this.
In step 5 we remove the inverter cable, but in step 6 we say inverter cable... again . Is this true?
It should say Status LED, not inverter.
Very informative, just fished following this guide. my replacement LCD came with the bracket that is normally attached to the bezel, so i had one extra (no brainer) step
