当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Before you reassemble the computer, double check that your new hard drive has the same jumper configuration as the old one. This ensures the IDE "Master-Slave" protocol isn't interrupted. Some systems do not require this, but if you are having issues booting up afterwards with the storage or the disc drive, this could be the source of the problem.
这个步骤还没有翻译 帮忙翻译一下
Take out the two T-15 screws that hold the fan brackets to the chassis.
Remove the four T-20 screws that hold the brackets onto the fan itself.
Now you can remove the fan from the computer. There may be an adhesive seal holding the fan to the chassis, so some force may be required.
6等其他人完成本指南。
6条评论
I don't see why it would be necessary... ??
anyone have a link for an adapter i can use to make any regular pc fan work in the imac g4? i was looking at a blue LED one on amazon and a guy said in the comments it would work but it needed an adapter but I can’t seem to find the correct one! plz help, thanks!
What size is the fan? Regular 3 pin connector?
