跳转到主内容
iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement
你所需要的
  1. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Bottom Plate: 步骤 1 中的图像 1,1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 2 中的图像 1,1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Bottom Plate Housing: 步骤 4 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Bottom Plate Housing: 步骤 4 中的图像 2,2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 5 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 5 中的图像 2,2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
  6. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Drive Carrier Assembly: 步骤 6 中的图像 1,3 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Drive Carrier Assembly: 步骤 6 中的图像 2,3 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement, Drive Carrier Assembly: 步骤 6 中的图像 3,3
    • Remove the 2 torx 10mm screws on the EMI shield
    • Carefully remove shield and copper tape
  7. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 7 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 7 中的图像 2,2
    • Remove the 4 10mm torx screws attatched to the drive carrier.
    • The drive carrier includes optical drive and hard drive.
  8. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 8 中的图像 1,1
    • Grasp the carrier with both hands on each side.
    • Remove the carrier by lifting up and out.
    • Pull gently but firmly. The carrier is meant to fit snugly.
  9. iMac G4 17 800 MHz EMC 1936 Drive Carrier Assembly Replacement: 步骤 9 中的图像 1,1
    • Flip the removed carrier to the right and pull out power cables.
结论
3等其他人完成本指南。
Courtney
于10/06/11注册
1,076 声望
创作了3篇指南
团队
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G22
4 名成员
创作了13篇指南
2条评论
What two screws in step 6
David Hunter - 回复
We need a "action" shot; we need to show an actual screwdriver unscrewing the screw.
David Hunter - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,330
