跳转到主内容
iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement
你所需要的
  1. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate: 步骤 1 中的图像 1,1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: 步骤 2 中的图像 1,1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate Housing: 步骤 4 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate Housing: 步骤 4 中的图像 2,2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: 步骤 5 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: 步骤 5 中的图像 2,2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
结论
6等其他人完成本指南。
Justin
于10/05/11注册
309 声望
创作了3篇指南
团队
Cal Poly, Team 21-22, Maness Fall 2011 Cal Poly, Team 21-22, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G22
4 名成员
创作了13篇指南
一条评论
If you do this - don't you still need to apply a fresh coat of thermal paste to the exposed ends of the two heat-sink posts (that separate when you open a G4 flatpanel this far) - my understanding was that the machine would overheat and you'd be left with didley squat!!
Gregg :O)
amicuset - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,195
