跳转到主内容
iMac G4 17 800 MHz EMC 1936 Battery Replacement
你所需要的
  1. iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: 步骤 1 中的图像 1,3 iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: 步骤 1 中的图像 2,3 iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • G4 bottom Plate with four captive Phillips screws
    • The bottom of the plate will list the serial number, MHz of the machine, standard RAM and hard drive size
  2. iMac G4 17 800 MHz EMC 1936 Battery Replacement: 步骤 2 中的图像 1,1
    • Here the plate has been removed exposing the slot for the Airport Card and User added RAM slot.
  3. iMac G4 17 800 MHz EMC 1936 Battery Replacement: 步骤 3 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the four T15 torx screws.
    • Set the unit on it's base, grasp the neck and tilt it to separate the base.
  4. iMac G4 17 800 MHz EMC 1936 Battery Replacement: 步骤 4 中的图像 1,2 iMac G4 17 800 MHz EMC 1936 Battery Replacement: 步骤 4 中的图像 2,2
    • The IDE cable unplugs first.
    • Locate the 3.6 volt 1/2 AA Lithium PRAM battery on the logic board and replace it.
结论
10等其他人完成本指南。
mayer
于01/04/10注册
685,316 声望
创作了12篇指南
团队
MacHale Enterprises MacHale Enterprises 的会员
Business
1 名成员
创作了18篇指南
2条评论
These directions do not explain how to do any step of the process particularly showing where the battery is and how to carefully remove the bottom plate without breaking the logic board connector or cables. Also they are redundant as there are already directions to replace the PRAM Battery on this site. There is no point in there being two sets of directions for the same fix.
Sheldon Buchler - 回复
Sad that none of the pictures actually show the battery! Look for the other iMac G4 battery guide its better, although it misses the step of recoating the heat sinks with thermal paste.
Netmammal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 15,260
