跳转到主内容
简介
This step will help you connect to wireless internet and get you back to surfing the internet faster than before. You can add a AirPort to your computer even if it did not originally come with one.
配件
没有特定配件。
  1. Place the computer monitor face down on a safe, harmless surface. Using a  Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Remove the metal plate from bottom of the iMac G4.
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Use a spudger to lift and remove the AirPort's antenna connector.
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
结论
14等其他人完成本指南。
Lilly
于2011年10月11日注册
620 信誉积分
创作了2篇指南
团队
Cal Poly, Team 5-32, Amido Fall 2011 Cal Poly, Team 5-32, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G32
4 名成员
创作了8篇指南
3条评论
Make sure to insert the AirPort Card with the label facing down, away from you.
Nathan Larsen - 回复
Does the antennae cable not plug into the card - Your illustration shows a large cable simply taped on top of the card and, as far as I can see, a smaller thinner cable that appears to be going to the card. I have the bigger cable in my iMac but it dues not appear to fit into the card - Do Inhave the wrong card or something?
roger - 回复
The big cable plugs into the card. The little cable is a drawing on the iMac to show you how the cable should go. You are right, Step 3 does show the cable on top of the card, not plugged into it.
Dave -
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 36
总计 7,754
