跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. iMac G3 Model M4984 Teardown, Logic Board: 步骤 1 中的图像 1,1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Teardown: 步骤 2 中的图像 1,1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Teardown: 步骤 3 中的图像 1,3 iMac G3 Model M4984 Teardown: 步骤 3 中的图像 2,3 iMac G3 Model M4984 Teardown: 步骤 3 中的图像 3,3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Teardown: 步骤 4 中的图像 1,3 iMac G3 Model M4984 Teardown: 步骤 4 中的图像 2,3 iMac G3 Model M4984 Teardown: 步骤 4 中的图像 3,3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Teardown: 步骤 5 中的图像 1,3 iMac G3 Model M4984 Teardown: 步骤 5 中的图像 2,3 iMac G3 Model M4984 Teardown: 步骤 5 中的图像 3,3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Teardown: 步骤 6 中的图像 1,2 iMac G3 Model M4984 Teardown: 步骤 6 中的图像 2,2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Teardown: 步骤 7 中的图像 1,3 iMac G3 Model M4984 Teardown: 步骤 7 中的图像 2,3 iMac G3 Model M4984 Teardown: 步骤 7 中的图像 3,3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Teardown: 步骤 8 中的图像 1,1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Teardown, Bottom Cover: 步骤 9 中的图像 1,1
    • To remove the bottom cover, remove these phillips screws, and pull the bottom cover off the iMac. (Start with the very back and use a flat head screwdriver to pop the main clip. The rest will come off relatively easily.)
  10. iMac G3 Model M4984 Teardown: 步骤 10 中的图像 1,3 iMac G3 Model M4984 Teardown: 步骤 10 中的图像 2,3 iMac G3 Model M4984 Teardown: 步骤 10 中的图像 3,3
    • Removing the faceplate:
    • Remove these phillips screws.
    • Now, pivot the faceplate up about 60 degrees and pull it away from the imac, with some wiggleing, it should come free
Chris Green
于10/11/09注册
37,065 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,485篇指南
一条评论
yo what happened to this lmao
Crystal Haugh - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 30
总计 9,158
