简介
The iMac uses an incredibly hard to get to power supply. It has 24-Pins. This will require taking the iMac fully apart.
你所需要的
The iMac G3. This was a great computer for the time, and had plenty of features.
Removing the front bezel:
There isn't a great position to put the iMac in to remove the front bezel. I recommend flipping it so it it like it would normally be positioned.
Remove these two Phillips screws.
Now, work your way around the bezel with a flathead screwdriver, and then, pivot it up towards the top, and remove it.
Removing the translucent plastic:
Removal of the front bezel will reveal two screw covers on the top, pop them off with a Phillips screwdriver.
Now, use a Phillips screwdriver to remove the screws.
You can now remove the plastic.
After taking out the screws, you remove the translucent plastic by pulling the translucent plastic up (if computer orientation is bottom side down), and to the sides, the latches look like hooks and are not pressure latches.
Do this for each side at a time
Tal Glazer - 回复
Now, swing the board out, and remove the following connectors:
AC Power
To System Fan
Don't remove this. It comes free with the logic board power.
To Display Driver
The connector that is attatched to the logic board; to remove it, simply thread it through the hole in the metal:
Now, you should be able to remove the power supply.
6等其他人完成本指南。
一条评论
i have exactly this problem with my vintage imac g3 took it to repair shop they said could not find it do you know where i can get this power supply and pay to have it installed
