跳转到主内容
iMac G3 Model M4984 Logic Board Replacement
你所需要的
  1. iMac G3 Model M4984 Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Logic Board Replacement: 步骤 2 中的图像 1,1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Logic Board Replacement: 步骤 3 中的图像 1,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 3 中的图像 2,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 3 中的图像 3,3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Logic Board Replacement: 步骤 4 中的图像 1,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 4 中的图像 2,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 4 中的图像 3,3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Logic Board Replacement: 步骤 5 中的图像 1,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 5 中的图像 2,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 5 中的图像 3,3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Logic Board Replacement: 步骤 6 中的图像 1,2 iMac G3 Model M4984 Logic Board Replacement: 步骤 6 中的图像 2,2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Logic Board Replacement: 步骤 7 中的图像 1,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 7 中的图像 2,3 iMac G3 Model M4984 Logic Board Replacement: 步骤 7 中的图像 3,3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Logic Board Replacement: 步骤 8 中的图像 1,1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
结论
13等其他人完成本指南。
Chris Green
于10/11/09注册
38,113 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,452篇指南
2指南评论
Just did this on my Grape 333 Mhz and on my Lime 333 Mhz which come from from the same place. Actually, I'm surprised that the Grape's logic board has a white IrDA connector which its twin doesn't have...
Nicolas Zbinden - 回复
Some corrections based on https://everymac.com/systems/apple/imac/... ... The Rev. A and B sold in 1998 were all Bondi Blue in color (bond-EYE). The 5 flavors launched in 1999, and could be called a Rev. C but I don't know if anyone calls them that. The 1999 models share the same Model number and ID as the Rev. A and B but with a different order number. As well as the colors they had a spec-bumped CPU and hard drive, and minor manufacturing changes including the removal of the internal Mezzanine connector.
Pierre Houston - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 94
总计 19,681
