跳转到主内容
iMac 2009-2010 SSD Upgrade (IcyDock)
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iMac 2009-2010 SSD Upgrade (IcyDock), SSD (2009-2010 IcyDock): 步骤 1 中的图像 1,3 iMac 2009-2010 SSD Upgrade (IcyDock), SSD (2009-2010 IcyDock): 步骤 1 中的图像 2,3 iMac 2009-2010 SSD Upgrade (IcyDock), SSD (2009-2010 IcyDock): 步骤 1 中的图像 3,3
    • Only follow the next ten steps if you are replacing your hard drive with an SSD kit.
    • Depress the enclosure's front plate latch with your finger. While holding the latch down, swing the plate out.
    • Remove the front plate.
  2. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 2 中的图像 1,3 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 2 中的图像 2,3 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 2 中的图像 3,3
    • Line up the small SATA connectors so that the narrow side of the connector on the SSD matches the narrow side on the enclosure connector.
    • Slide the drive in through the front of the enclosure until the SATA connector is fully seated.
    • The SSD connects with the enclosure in only one way. If the connectors are not lining up, rotate the SSD and try again.
  3. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 3 中的图像 1,1
    • You may optionally install two Philips #1 screws that came with the enclosure kit to secure the SSD in the enclosure.
  4. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 4 中的图像 1,2 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 4 中的图像 2,2
    • Plug the included sensor-enabled SATA power cable into the wide side of the enclosure's SATA connector.
    • The cable is keyed to connect in only one way. If you can't connect the cable, rotate it 180°, and try again.
  5. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 5 中的图像 1,3 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 5 中的图像 2,3 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 5 中的图像 3,3
    • Peel the backing off of the adhesive back of the small temperature sensor board.
    • Adhere the temperature sensor board to an exposed, metal area of the surface of the SSD, as close as possible to the SATA connector.
    • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  6. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 6 中的图像 1,1
    • Install the mounting pins from the old hard drive onto the sides of the enclosure.
    • The holes on the enclosure may not be threaded, so screwing the mounting pins into them may require extra effort. Take your time and screw them in slowly, making sure they go in straight.
  7. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 7 中的图像 1,2 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 7 中的图像 2,2
    • Attach any mounting brackets removed from the old hard drive onto the enclosure.
  8. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 8 中的图像 1,2 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 8 中的图像 2,2
    • Connect the iMac's SATA power cable to the new temperature-capable SATA power cable.
    • Route the SATA cables where they will not interfere with any other components.
  9. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 9 中的图像 1,2 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 9 中的图像 2,2
    • Connect the iMac's SATA data cable to the enclosure's SATA data connector.
  10. iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 10 中的图像 1,3 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 10 中的图像 2,3 iMac 2009-2010 SSD Upgrade (IcyDock): 步骤 10 中的图像 3,3
    • Find a connector on the motherboard labeled HD TMP or HDD TEMP.
    • If you have trouble locating it, trace the two-wire temperature cable you disconnected from the old hard drive.
    • If the previous temperature cable is still connected to the board here, disconnect and remove it. You will no longer need it.
    • Connect the temperature sensor's two-wire red-black cable to the motherboard plug labeled HD TMP or HDD TEMP.
    • The connector is keyed to fit in one way only. If it seems like the connector is not fitting the socket, flip the connector and try again.
    • Route the excess wire so it does not interfere with any other components.
结论
Arthur Shi
于01/03/18注册
252,690 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 3,713
