当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
这份指南将帮助你更换或者升级你的硬盘。
同时,这也是一份帮助你将机械硬盘升级为SSD的指南。这里将阐述如何安装SSD温度检测线,以使iMac的散热风扇能够以正确的转速运行。
在开始对你的iMac进行任何的动作之前:拔下iMac的电源线,并且长按电源按钮10秒,以确保断开内部的全部电源供应。
必须非常小心,不要接触供电部分的任何电容的引脚或者暴露焊点。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Lay the display face down on a flat, soft surface.
If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
将您的设备,遵循这些指示,逆向重组。
将您的设备,遵循这些指示,逆向重组。
341等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
63条评论
Note that if you are replacing the hard drive with a non-Apple hard drive, then you will have problems with the fan running full speed constantly (see http://blog.macsales.com/10206-further-e...). Basically, you'll need to either install a $30 piece of software to control the fans or short out some wires.
You don´t need to short out the wires, just install the free SSD FAN CONTROL app from EXIRION.NET und you´ll be fine :D
remember after the glass, to get the aluminum front off, remove the bay for the memory upgrade on the bottom first before you remove the torx screws ans lift to access the bottom case (Between step 2 and 3)
I'm looking to replace my 3.5" HDD in my iMac (mid-2011) with a 2.5" SSD. Will I need an adapter for this?
Absolutly. You can buy a official one on the Apple Store. I reccommend the dual-drive (HDD & SDD) tho.
