跳转到主内容
iLive IKBC384S Motherboard Replacement
你所需要的
  1. iLive IKBC384S Motherboard Replacement, Top Cover: 步骤 1 中的图像 1,2 iLive IKBC384S Motherboard Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: 步骤 2 中的图像 1,2 iLive IKBC384S Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: 步骤 3 中的图像 1,2 iLive IKBC384S Motherboard Replacement: 步骤 3 中的图像 2,2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: 步骤 5 中的图像 1,2 iLive IKBC384S Motherboard Replacement: 步骤 5 中的图像 2,2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: 步骤 6 中的图像 1,1
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: 步骤 7 中的图像 1,1
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
结论
Tracy Walts
于03/21/17注册
201 声望
创作了2篇指南
团队
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 9
总计 274
