跳转到主内容
iLive IKBC384S Disk Drive Replacement
你所需要的
  1. iLive IKBC384S Disk Drive Replacement, Top Cover: 步骤 1 中的图像 1,2 iLive IKBC384S Disk Drive Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Disk Drive Replacement: 步骤 2 中的图像 1,2 iLive IKBC384S Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Disk Drive Replacement: 步骤 3 中的图像 1,2 iLive IKBC384S Disk Drive Replacement: 步骤 3 中的图像 2,2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Disk Drive Replacement, Disk Drive: 步骤 4 中的图像 1,2 iLive IKBC384S Disk Drive Replacement, Disk Drive: 步骤 4 中的图像 2,2
    • Remove all four screws(13.5 mm in length) that are securing the device
  5. iLive IKBC384S Disk Drive Replacement: 步骤 5 中的图像 1,2 iLive IKBC384S Disk Drive Replacement: 步骤 5 中的图像 2,2
    • Remove both of the connected cords on the motherboard.
    • Also remove the flat ribbon cable that is connected to the motherboard.
    • Once you have removed all screws and cables connected to motherboard the disk drive can be easily removed
结论
Allen Dover
于03/21/17注册
401 声望
创作了4篇指南
团队
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 410
