跳转到主内容
iLive IKBC384S Audio Speakers Replacement
你所需要的
  1. iLive IKBC384S Audio Speakers Replacement, Top Cover: 步骤 1 中的图像 1,2 iLive IKBC384S Audio Speakers Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Audio Speakers Replacement: 步骤 2 中的图像 1,2 iLive IKBC384S Audio Speakers Replacement: 步骤 2 中的图像 2,2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Audio Speakers Replacement: 步骤 3 中的图像 1,2 iLive IKBC384S Audio Speakers Replacement: 步骤 3 中的图像 2,2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Audio Speakers Replacement, Audio Speakers: 步骤 4 中的图像 1,2 iLive IKBC384S Audio Speakers Replacement, Audio Speakers: 步骤 4 中的图像 2,2
    • Be sure to unscrew (3 mm) the two plastic brackets on each speaker, use iOpener or heat gun they are glued onto speakers, please do not discard.
  5. iLive IKBC384S Audio Speakers Replacement: 步骤 5 中的图像 1,1
    • Unplug both of the speakers from the motherboard.
结论
Allen Dover
于03/21/17注册
401 声望
创作了4篇指南
团队
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017 的会员
TTU-BENNETT-S17S46G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 438
