跳转到主内容
iHome iP21 Motherboard Replacement
你所需要的
  1. iHome iP21 Motherboard Replacement, Base: 步骤 1 中的图像 1,3 iHome iP21 Motherboard Replacement, Base: 步骤 1 中的图像 2,3 iHome iP21 Motherboard Replacement, Base: 步骤 1 中的图像 3,3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Motherboard Replacement, Housing: 步骤 2 中的图像 1,2 iHome iP21 Motherboard Replacement, Housing: 步骤 2 中的图像 2,2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Motherboard Replacement, Circuit board: 步骤 3 中的图像 1,1
    • Follow the prerequisite guide to remove the main housing.
  4. iHome iP21 Motherboard Replacement, Circuit board mount: 步骤 4 中的图像 1,1
    • Remove the two 7mm screws from the circuit board
  5. iHome iP21 Motherboard Replacement, Mounting Bracket: 步骤 5 中的图像 1,1
    • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
  6. iHome iP21 Motherboard Replacement, Cables: 步骤 6 中的图像 1,3 iHome iP21 Motherboard Replacement, Cables: 步骤 6 中的图像 2,3 iHome iP21 Motherboard Replacement, Cables: 步骤 6 中的图像 3,3
    • Peel the glue from each of the three ribbon cable connections.
    • Remove the solder joints from the back of each ribbon cable.
    • Remove the ground wires by removing the solder joints on the back of the housing.
  7. iHome iP21 Motherboard Replacement, Detach cables from circuit board: 步骤 7 中的图像 1,3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: 步骤 7 中的图像 2,3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: 步骤 7 中的图像 3,3
    • Remove glue from 3 ribbon cables from circuit board using fingers
    • Detach speaker cables from circuit board with soldering iron
    • Remove 3 ribbon cables with soldering iron
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 277
