跳转到主内容
iHome iP21 Display LED Replacement
你所需要的
  1. iHome iP21 Display LED Replacement, Base: 步骤 1 中的图像 1,3 iHome iP21 Display LED Replacement, Base: 步骤 1 中的图像 2,3 iHome iP21 Display LED Replacement, Base: 步骤 1 中的图像 3,3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Display LED Replacement, Housing: 步骤 2 中的图像 1,2 iHome iP21 Display LED Replacement, Housing: 步骤 2 中的图像 2,2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Display LED Replacement, Remove Speaker Assembly: 步骤 3 中的图像 1,1
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  4. iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: 步骤 4 中的图像 1,2 iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: 步骤 4 中的图像 2,2
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
  5. iHome iP21 Display LED Replacement, Display circuit board: 步骤 5 中的图像 1,3 iHome iP21 Display LED Replacement, Display circuit board: 步骤 5 中的图像 2,3 iHome iP21 Display LED Replacement, Display circuit board: 步骤 5 中的图像 3,3
    • Remove six 6mm screws from display circuit board.
    • Press black holding clips down and outward to release display circuit board.
    • Lift display circuit board to detach it from the housing.
  6. iHome iP21 Display LED Replacement, Cables: 步骤 6 中的图像 1,2 iHome iP21 Display LED Replacement, Cables: 步骤 6 中的图像 2,2
    • Desolder the solder joints connecting the grounding cable to the display circuit board.
    • Remove glue from the ribbon cables with your fingers. Grasp and pull the glue to remove it from the circuit board.
    • Desolder the solder joints connecting the three ribbon cables to the back of the display circuit board.
    • Desolder the solder joints connecting the two grounding cables to the back of the display circuit board.
    • Desolder the solder joints connecting the two grounding cables to the back of the main housing.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 436
