跳转到主内容
iHome iP1 Speaker(s) Replacement
你所需要的
  1. iHome iP1 Speaker(s) Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Orient the iHome upside down with the speakers facing away from you.
  2. iHome iP1 Speaker(s) Replacement: 步骤 2 中的图像 1,2 iHome iP1 Speaker(s) Replacement: 步骤 2 中的图像 2,2
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  3. iHome iP1 Speaker(s) Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  4. iHome iP1 Speaker(s) Replacement, Speaker(s): 步骤 4 中的图像 1,3 iHome iP1 Speaker(s) Replacement, Speaker(s): 步骤 4 中的图像 2,3 iHome iP1 Speaker(s) Replacement, Speaker(s): 步骤 4 中的图像 3,3
    • Disconnect the white/black wires from the edges of the motherboard by pulling them away from their connection.
    • You may need to remove some black foam tape in order to fully disconnect some of the wires.
  5. iHome iP1 Speaker(s) Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the glue attaching the wires to the housing using a metal spudger kit.
    • The glue is only used to keep the wires in place. It does not affect the function of the iHome.
    • If not all the glue can be removed at this step, remove the remaining glue after Step 8, where you can access the glue from the inside of the speaker housing.
  6. iHome iP1 Speaker(s) Replacement: 步骤 6 中的图像 1,3 iHome iP1 Speaker(s) Replacement: 步骤 6 中的图像 2,3 iHome iP1 Speaker(s) Replacement: 步骤 6 中的图像 3,3
    • Rotate the iHome so that the speakers are facing you.
    • Remove the speaker covers by pulling them off of the faceplate.
    • After this step, this guide only shows how to replace the left speaker. To remove the right speaker, follow the remaining steps as if they are mirrored.
  7. iHome iP1 Speaker(s) Replacement: 步骤 7 中的图像 1,1
    • Remove the four 12.0 mm Phillips #2 screws from the edges of the speaker.
  8. iHome iP1 Speaker(s) Replacement: 步骤 8 中的图像 1,2 iHome iP1 Speaker(s) Replacement: 步骤 8 中的图像 2,2
    • Remove the speaker from the housing by gripping the rubber ring near the edge of the speaker and pulling it away from the faceplate.
    • Be careful not to tear the rubber. Once the speaker is loose enough, you can remove it from the housing by grabbing the metal speaker edges.
  9. iHome iP1 Speaker(s) Replacement: 步骤 9 中的图像 1,3 iHome iP1 Speaker(s) Replacement: 步骤 9 中的图像 2,3 iHome iP1 Speaker(s) Replacement: 步骤 9 中的图像 3,3
    • Remove the speaker from the iHome by feeding the black/white wires through the hole on the opposite side of the housing.
结论
2等其他人完成本指南。
Joshua Tran
于10/06/16注册
140 声望
撰写一个指南
团队
Cal Poly, Team 20-1, Livingston Fall 2016 Cal Poly, Team 20-1, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G1
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 923
