跳转到主内容
iHome iP1 Motherboard Replacement
你所需要的
  1. iHome iP1 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Orient the iHome upside down with the speakers facing away from you.
  2. iHome iP1 Motherboard Replacement: 步骤 2 中的图像 1,2 iHome iP1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  3. iHome iP1 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  4. iHome iP1 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 iHome iP1 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
    • The order in which the wire bundles are removed does not matter.
    • You may need to remove some black foam tape in order fully disconnect some of the wires.
  5. iHome iP1 Motherboard Replacement: 步骤 5 中的图像 1,2 iHome iP1 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
  6. iHome iP1 Motherboard Replacement: 步骤 6 中的图像 1,2 iHome iP1 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
  7. iHome iP1 Motherboard Replacement: 步骤 7 中的图像 1,3 iHome iP1 Motherboard Replacement: 步骤 7 中的图像 2,3 iHome iP1 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
结论
3等其他人完成本指南。
Sachin Shenoi
于10/10/16注册
333 声望
创作了2篇指南
团队
Cal Poly, Team 20-1, Livingston Fall 2016 Cal Poly, Team 20-1, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G1
4 名成员
创作了7篇指南
5条评论
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - 回复
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - 回复
Were you able to buy the motherboard?
Rodrigo -
Rodrigo
rodrigo@r7criacoes.com.br
Rodrigo - 回复
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
Riyu PC - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 1,737
