跳转到主内容
iHome iH9 Speaker Replacement
你所需要的
  1. iHome iH9 Speaker Replacement, Backup Batteries: 步骤 1 中的图像 1,3 iHome iH9 Speaker Replacement, Backup Batteries: 步骤 1 中的图像 2,3 iHome iH9 Speaker Replacement, Backup Batteries: 步骤 1 中的图像 3,3
    • Pull the tab towards you and lift up to remove the battery cover.
    • Remove the two AA batteries.
  2. iHome iH9 Speaker Replacement, Opening the iHome iH9: 步骤 2 中的图像 1,1
    • Unscrew the four 8mm Phillips #2 screws.
    • Unscrew the six 25mm Phillips #2 screws.
    • Reinstall the backup battery cover so it is out of the way.
  3. iHome iH9 Speaker Replacement: 步骤 3 中的图像 1,3 iHome iH9 Speaker Replacement: 步骤 3 中的图像 2,3 iHome iH9 Speaker Replacement: 步骤 3 中的图像 3,3
    • Pry the backplate up with a plastic opening tool between the back plate and the speaker grill.
    • Be careful when lifting the bottom plate up; there is a short white and orange 4-pin connector attached to its underside.
    • Lift the bottom plate up while making sure the connector remains attached.
  4. iHome iH9 Speaker Replacement: 步骤 4 中的图像 1,3 iHome iH9 Speaker Replacement: 步骤 4 中的图像 2,3 iHome iH9 Speaker Replacement: 步骤 4 中的图像 3,3
    • Use your hands to flip the backing plate away from you and rest it upside down on the iH9.
    • Unplug the white and orange 4-pin connector by pulling it in the direction of the wires.
    • Set the backing plate aside.
  5. iHome iH9 Speaker Replacement: 步骤 5 中的图像 1,1
    • Place the device so that the speaker grill is face down.
    • Remove the two 10mm Phillips #2 screws on interior sides of the speaker housings.
  6. iHome iH9 Speaker Replacement: 步骤 6 中的图像 1,2 iHome iH9 Speaker Replacement: 步骤 6 中的图像 2,2
    • Place the iH9 upside down.
    • Wires connect the core assembly to the housing; do not attempt to pull the core assembly completely out.
    • Using both hands, pull the housing siding away from the device while simultaneously lifting the motherboard and speaker assembly straight up.
    • Repeat for the other side.
  7. iHome iH9 Speaker Replacement: 步骤 7 中的图像 1,1
    • Stand the iH9 on its grill.
    • Separate the motherboard and speaker assembly by rocking it back and forth and pulling the assembly towards you.
    • Remove the small back panel.
  8. iHome iH9 Speaker Replacement: 步骤 8 中的图像 1,3 iHome iH9 Speaker Replacement: 步骤 8 中的图像 2,3 iHome iH9 Speaker Replacement: 步骤 8 中的图像 3,3
    • Firmly pull the wide 9-pin connector with black covering on the underside of the upper housing to unplug it.
    • Lay the housing and core assembly flat and close to each one another.
  9. iHome iH9 Speaker Replacement: 步骤 9 中的图像 1,2 iHome iH9 Speaker Replacement: 步骤 9 中的图像 2,2
    • Unplug the narrow 9-pin connector from the motherboard.
  10. iHome iH9 Speaker Replacement: 步骤 10 中的图像 1,1
    • Cut the zip tie holding the wires together with a wire cutter. The two sides of the device housing are now fully separated.
  11. iHome iH9 Speaker Replacement, Speaker: 步骤 11 中的图像 1,1
    • Set the iHome iH9 speaker and mother board assembly upright on the speaker grill.
    • Remove the black ground wire from the grill by pulling in the direction of the wire.
    • The wire is located next to the left speaker housing.
  12. iHome iH9 Speaker Replacement: 步骤 12 中的图像 1,1
    • Unplug the 3-pin connector for the infrared sensor by pulling in the direction of the cable.
    • The wire is near the ground wire tab.
  13. iHome iH9 Speaker Replacement: 步骤 13 中的图像 1,2 iHome iH9 Speaker Replacement: 步骤 13 中的图像 2,2
    • Set the iH9 flat down with the solder side of the motherboard up and the speaker grill facing away.
    • With a nylon or metal spudger, pry the speaker grill up and forward from the two retaining flanges on the left and right speaker housings.
    • Set the speaker grill aside.
  14. iHome iH9 Speaker Replacement: 步骤 14 中的图像 1,1
    • Flip the iH9 back over, exposing the motherboard components.
    • For the right speaker, unplug the speaker wire by pulling in the direction of the wire (pictured).
    • For the left speaker, unplug the speaker wire by pulling in the direction of the wire.
  15. iHome iH9 Speaker Replacement: 步骤 15 中的图像 1,2 iHome iH9 Speaker Replacement: 步骤 15 中的图像 2,2
    • Remove the four 14mm Phillips #1 screws on each of the speaker's four corners.
    • The right speaker is pictured; the same procedure is necessary to replace the left speaker.
    • Remove the speaker.
  16. iHome iH9 Speaker Replacement: 步骤 16 中的图像 1,1
结论
另外一个人完成了本指南。
Curtis Wathne
于01/31/15注册
397 声望
创作了3篇指南
团队
Cal Poly, Team 8-39, Amido Winter 2015 Cal Poly, Team 8-39, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G39
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 602
