简介
This is a replacement guide for the speaker on an iHome iH5.
配件
无需配件。
  1. Unscrew the bottom of the iHome at the marked points with a #2 phillips
    • Unscrew the bottom of the iHome at the marked points with a #2 phillips
  2. Remove wires from the logic board (tweezers or pliers are helpful)
    • Remove wires from the logic board (tweezers or pliers are helpful)
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Unscrew at the marked points with #2 Phillips screwdriver.
    • Unscrew at the marked points with #2 Phillips screwdriver.
  5. Flip the board over. There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Flip the board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires for the board with tweezers. If they're tight pliers can be used instead.
    • There is one in the orange box.
    • There are two in the yellow box.
    • The are five in the green box.
  6. Remove the two screws with a #2 Phillips screwdriver. Flip the device on its front then remove the two screws with a #2 Phillips screwdriver. Grab the speaker and pull it up until it looks like the speaker on the right. Then pull is straight back like shown with the speaker on the left.
    • Remove the two screws with a #2 Phillips screwdriver.
    • Flip the device on its front then remove the two screws with a #2 Phillips screwdriver.
    • Grab the speaker and pull it up until it looks like the speaker on the right. Then pull is straight back like shown with the speaker on the left.
  7. Remove the four screws with a #2 Phillips screwdriver.
    • Remove the four screws with a #2 Phillips screwdriver.
    • Replace the broken speaker.
结论
Maggie Hill
于2014年03月20日注册
367 信誉积分
创作了3篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 466
