跳转到主内容
iHome iH5 Dials Replacement
你所需要的
  1. iHome iH5 Dials Replacement, Dials: 步骤 1 中的图像 1,1
    • Remove the eight screws from the bottom side of the iHome.
  2. iHome iH5 Dials Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the cover to expose the inside.
    • With pliers, or tweezers,if needed, remove the three wire harnesses by gently pulling straight up on them.
  3. iHome iH5 Dials Replacement: 步骤 3 中的图像 1,1
    • Remove the 5 screws with a #2 Phillips screwdriver.
  4. iHome iH5 Dials Replacement: 步骤 4 中的图像 1,1
    • Remove all wire harnesses from the bottom of the board. There eight wire harnesses.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
  5. iHome iH5 Dials Replacement: 步骤 5 中的图像 1,3 iHome iH5 Dials Replacement: 步骤 5 中的图像 2,3 iHome iH5 Dials Replacement: 步骤 5 中的图像 3,3
    • Remove the two screws from the speakers with a #2 Phillips screwdriver.
    • Turn the device on its front side and remove the two screws with a #2 Phillips screwdriver.
    • Pull the speaker up from the back as shown with the speaker on the right. Then pull the speaker straight back as shown with the speaker on the left.
  6. iHome iH5 Dials Replacement: 步骤 6 中的图像 1,1
    • Remove the front piece by pulling up until it hits the plastic pieces sticking out from the display screen. Then pull it out horizontally from the device.
  7. iHome iH5 Dials Replacement: 步骤 7 中的图像 1,1
    • Remove the three screw from the dial with a #2 Phillips screwdriver.
  8. iHome iH5 Dials Replacement: 步骤 8 中的图像 1,1
    • Pull back the circuit board to access the plastic piece.
    • Lift to separate the plastic piece from the dial.
    • Replace the broken piece.
结论
3等其他人完成本指南。
Maggie Hill
于03/20/14注册
379 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,046
