跳转到主内容
iHome iH3L Batteries Replacement
你所需要的
  1. iHome iH3L Batteries Replacement, Batteries: 步骤 1 中的图像 1,2 iHome iH3L Batteries Replacement, Batteries: 步骤 1 中的图像 2,2
    • Using your finger, pry the tab on the battery cover to remove the battery cover on the back of the iHome to access the batteries.
  2. iHome iH3L Batteries Replacement: 步骤 2 中的图像 1,3 iHome iH3L Batteries Replacement: 步骤 2 中的图像 2,3 iHome iH3L Batteries Replacement: 步骤 2 中的图像 3,3
    • With the battery panel off, remove the batteries. Use your hands or a plastic spudger to remove the batteries.
  3. iHome iH3L Batteries Replacement: 步骤 3 中的图像 1,2 iHome iH3L Batteries Replacement: 步骤 3 中的图像 2,2
    • When removing the batteries make sure to remove corrosion. Wear gloves when removing corrosion and use proper disposal.
    • Make sure to avoid contact with your eyes or mouth as it can cause irritation and lead to other problems.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 326
