跳转到主内容
iHome iH27B iPod Adapter Replacement
你所需要的
  1. iHome iH27B iPod Adapter Replacement, Adapter: 步骤 1 中的图像 1,1
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
  2. iHome iH27B iPod Adapter Replacement: 步骤 2 中的图像 1,1
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
  3. iHome iH27B iPod Adapter Replacement: 步骤 3 中的图像 1,3 iHome iH27B iPod Adapter Replacement: 步骤 3 中的图像 2,3 iHome iH27B iPod Adapter Replacement: 步骤 3 中的图像 3,3
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
  4. iHome iH27B iPod Adapter Replacement: 步骤 4 中的图像 1,2 iHome iH27B iPod Adapter Replacement: 步骤 4 中的图像 2,2
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
  5. iHome iH27B iPod Adapter Replacement: 步骤 5 中的图像 1,1
    • Pull out the adapter, and replace it with the new one.
结论
另外一个人完成了本指南。
John Kraemer
于10/09/12注册
76 声望
创作了9篇指南
团队
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G21
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 2,491
