跳转到主内容
iHome iH27B Power Connector Replacement
你所需要的
  1. iHome iH27B Power Connector Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
    • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
  2. iHome iH27B Power Connector Replacement: 步骤 2 中的图像 1,3 iHome iH27B Power Connector Replacement: 步骤 2 中的图像 2,3 iHome iH27B Power Connector Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
    • Remove the plastic slide from its location and set it aside.
    • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
    • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
    • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
    • Set the plastic covering and the watch battery aside.
  3. iHome iH27B Power Connector Replacement: 步骤 3 中的图像 1,1
    • Remove the following screws:
    • Eight 10 mm using the Phillips #0 on the bottom of your device.
    • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
  4. iHome iH27B Power Connector Replacement: 步骤 4 中的图像 1,1
    • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
    • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
  5. iHome iH27B Power Connector Replacement: 步骤 5 中的图像 1,1
    • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
    • You should have visible access to most of the components inside the iHome now.
  6. iHome iH27B Power Connector Replacement, Power Connector: 步骤 6 中的图像 1,2 iHome iH27B Power Connector Replacement, Power Connector: 步骤 6 中的图像 2,2
    • Firmly grasp the power connector, which is the plastic rectangular piece with the white and black wires connected to it.
    • Pull upwards and dislodge the connector.
  7. iHome iH27B Power Connector Replacement: 步骤 7 中的图像 1,1
    • Using the scissors on your wire strippers, cut the connecting wires.
    • Using your wire strippers, remove about 1/4 " of the plastic tubing surrounding the end of your exposed wire, careful to not damage the wires.
    • Using a wire-nut or electrician's tape, connect the wires of the replacement power connector to your exposed wires. Connect white wire to white, and black to black.
结论
John Kraemer
于10/09/12注册
76 声望
创作了9篇指南
团队
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G21
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,251
