跳转到主内容
iHome iD95 Speakers Replacement
你所需要的
  1. iHome iD95 Speakers Replacement, Backup Battery: 步骤 1 中的图像 1,1
    • Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
    • Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
  2. iHome iD95 Speakers Replacement: 步骤 2 中的图像 1,1
    • Remove the 10 mm-length, 5 mm-head screw using a Phillips #1 screwdriver.
  3. iHome iD95 Speakers Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to take out the backup battery.
  4. iHome iD95 Speakers Replacement, Bottom Cover: 步骤 4 中的图像 1,1
    • Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
  5. iHome iD95 Speakers Replacement: 步骤 5 中的图像 1,2 iHome iD95 Speakers Replacement: 步骤 5 中的图像 2,2
    • The bottom cover is attached to the back cover by two plastic clips. Don't use excessive force.
    • Insert a plastic opening tool between the edge of the bottom cover and the main body.
    • Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
    • Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
  6. iHome iD95 Speakers Replacement: 步骤 6 中的图像 1,2 iHome iD95 Speakers Replacement: 步骤 6 中的图像 2,2
    • Potential for device damage: Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
    • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
    • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
  7. iHome iD95 Speakers Replacement: 步骤 7 中的图像 1,2 iHome iD95 Speakers Replacement: 步骤 7 中的图像 2,2
    • Apply the same techniques from the previous step to remove the remaining side panel.
  8. iHome iD95 Speakers Replacement: 步骤 8 中的图像 1,3 iHome iD95 Speakers Replacement: 步骤 8 中的图像 2,3 iHome iD95 Speakers Replacement: 步骤 8 中的图像 3,3
    • Locate the two plastic clips holding the bottom and back cover together.
    • Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
    • Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
    • This is the hardest step because the angle is awkward and the visibility is poor. If possible, have someone hold the device or provide lighting.
    • Once a clip has been removed, hold the bottom cover open so the clip will not fall back into place. One clip remains to be removed; you are almost there!
  9. iHome iD95 Speakers Replacement: 步骤 9 中的图像 1,2 iHome iD95 Speakers Replacement: 步骤 9 中的图像 2,2
    • Use the same steps to remove the remaining clip.
    • The bottom cover is still connected to the motherboard by wiring.
  10. iHome iD95 Speakers Replacement: 步骤 10 中的图像 1,2 iHome iD95 Speakers Replacement: 步骤 10 中的图像 2,2
    • Use a plastic opening tool to pry off the white ZIF connector joining the wires to the motherboard.
    • Don't pull the wires. Take your time using a plastic opening tool.
  11. iHome iD95 Speakers Replacement, Speakers: 步骤 11 中的图像 1,1
    • Take out four 14 mm screws using a Phillips #1 screwdriver.
  12. iHome iD95 Speakers Replacement: 步骤 12 中的图像 1,3 iHome iD95 Speakers Replacement: 步骤 12 中的图像 2,3 iHome iD95 Speakers Replacement: 步骤 12 中的图像 3,3
    • Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
    • Do not pull on the speaker wires directly. Continue to use a plastic opening tool.
  13. iHome iD95 Speakers Replacement: 步骤 13 中的图像 1,1
    • Lift and remove both speakers.
结论
2等其他人完成本指南。
Craig Cary
于04/18/13注册
52 声望
撰写一个指南
团队
Cal Poly, Team 12-37, Amido Spring 2013 Cal Poly, Team 12-37, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G37
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 893
