跳转到主内容
iHome iBT84 Motherboard Replacement
你所需要的
  1. iHome iBT84 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 iHome iBT84 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Motherboard Replacement: 步骤 2 中的图像 1,2 iHome iBT84 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Motherboard Replacement: 步骤 3 中的图像 1,3 iHome iBT84 Motherboard Replacement: 步骤 3 中的图像 2,3 iHome iBT84 Motherboard Replacement: 步骤 3 中的图像 3,3
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Motherboard Replacement: 步骤 4 中的图像 1,1
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 984
