跳转到主内容
iHome iBT230 Motherboard Replacement
你所需要的
  1. iHome iBT230 Motherboard  Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the four 5.5 mm Phillips Head #00 screws from the bottom palate of the iBT230.
  2. iHome iBT230 Motherboard  Replacement: 步骤 2 中的图像 1,2 iHome iBT230 Motherboard  Replacement: 步骤 2 中的图像 2,2
    • Grip the top of the iBT230 by placing your thumb on the back portion, where the USB port is located. Pull up, and you should notice various different colored wires, connected to the Main Motherboard.
  3. iHome iBT230 Motherboard  Replacement: 步骤 3 中的图像 1,3 iHome iBT230 Motherboard  Replacement: 步骤 3 中的图像 2,3 iHome iBT230 Motherboard  Replacement: 步骤 3 中的图像 3,3
    • Unplug the connectors from all sides of the iBT230, and unplug the wire connected to the screen.
    • Make sure to note which wire goes where, you don't want to re-solder the wires into the incorrect ports!
  4. iHome iBT230 Motherboard  Replacement: 步骤 4 中的图像 1,2 iHome iBT230 Motherboard  Replacement: 步骤 4 中的图像 2,2
    • On the bottom component where the green Main Motherboard is located, remove the two 5.5 mm Phillips #00 screws.
    • The old Motherboard will come free from the bottom of the iBT230.
结论
2等其他人完成本指南。
Bilal Siddiqui
于04/10/17注册
376 声望
创作了3篇指南
团队
UW Tacoma, Team S3-G6, Liner Spring 2017 UW Tacoma, Team S3-G6, Liner Spring 2017 的会员
UWT-LINER-S17S3G6
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 626
