跳转到主内容
iHome iBT16 Motherboard Replacement
你所需要的
  1. iHome iBT16 Motherboard Replacement, Base Plate: 步骤 1 中的图像 1,2 iHome iBT16 Motherboard Replacement, Base Plate: 步骤 1 中的图像 2,2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: 步骤 2 中的图像 1,2 iHome iBT16 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 iHome iBT16 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 iHome iBT16 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: 步骤 4 中的图像 1,2 iHome iBT16 Motherboard Replacement: 步骤 4 中的图像 2,2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic cover from the power switch actuator on the motherboard.
结论
Joseph Hazel
于03/24/17注册
353 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,155
