跳转到主内容
iHome iBN97 Display Screen Replacement
你所需要的
  1. iHome iBN97 Display Screen Replacement, Bottom Plate Screws: 步骤 1 中的图像 1,3 iHome iBN97 Display Screen Replacement, Bottom Plate Screws: 步骤 1 中的图像 2,3 iHome iBN97 Display Screen Replacement, Bottom Plate Screws: 步骤 1 中的图像 3,3
    • This disassembly involves the removal of many components and screws. Be sure to remember which screws go where, and not to lose any parts.
    • All the screws are size 2 except for the ones in Step 9.
    • Flip the iHome upside down.
    • You should see six pocketed Phillip's head screws.
    • You should also see 2 visible Phillip head screws.
    • Using a long neck Phillips head screwdriver, remove the screws.
    • The long neck screwdriver is only necessary for this step. If it works well in the following steps, that is fine; just be sure to use the right tool for the right job.
  2. iHome iBN97 Display Screen Replacement, Bottom Plate Removal: 步骤 2 中的图像 1,3 iHome iBN97 Display Screen Replacement, Bottom Plate Removal: 步骤 2 中的图像 2,3 iHome iBN97 Display Screen Replacement, Bottom Plate Removal: 步骤 2 中的图像 3,3
    • Slightly lift the front end with the support.
    • Insert the flat end of the spudger and slide it along the edge.
    • The case should pop out easily. Remove the piece by lifting it straight out.
  3. iHome iBN97 Display Screen Replacement, Backup Battery Disconnection: 步骤 3 中的图像 1,3 iHome iBN97 Display Screen Replacement, Backup Battery Disconnection: 步骤 3 中的图像 2,3 iHome iBN97 Display Screen Replacement, Backup Battery Disconnection: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a pair of tweezers, remove the ribbon cable connector at the backup battery.
    • Be sure not to tug on the cables themselves. This could result in damaging the cables.
    • If tweezers are too difficult to use, it is ok to use your fingers, just so long as you don't put a lot of tension on the cables.
  4. iHome iBN97 Display Screen Replacement, Logic Board Removal: 步骤 4 中的图像 1,2 iHome iBN97 Display Screen Replacement, Logic Board Removal: 步骤 4 中的图像 2,2
    • Remove the 4 screws located on the logic board.
    • Gently lift the front side of the board towards you
    • Careful not to pull it out forcefully, there are still many cables attached to the logic board.
  5. iHome iBN97 Display Screen Replacement, Logic Board Connections Removal: 步骤 5 中的图像 1,2 iHome iBN97 Display Screen Replacement, Logic Board Connections Removal: 步骤 5 中的图像 2,2
    • Remove the 4 two-wire extension cables and the ribbon cable connected to the unit.
    • The logic board will still be attached to the unit by a flat ribbon cable and a radio wire.
    • Set the logic board next to the unit.
  6. iHome iBN97 Display Screen Replacement, Speaker Removal: 步骤 6 中的图像 1,3 iHome iBN97 Display Screen Replacement, Speaker Removal: 步骤 6 中的图像 2,3 iHome iBN97 Display Screen Replacement, Speaker Removal: 步骤 6 中的图像 3,3
    • Remove the 4 Phillips head screws that attach the speakers to the unit.
    • There are 2 more screws for each speaker. The speakers are symmetrical. Remove the 4 screws to free both speakers.
    • Gently lift each speaker out of the unit and set aside.
  7. iHome iBN97 Display Screen Replacement, Bluetooth Removal: 步骤 7 中的图像 1,3 iHome iBN97 Display Screen Replacement, Bluetooth Removal: 步骤 7 中的图像 2,3 iHome iBN97 Display Screen Replacement, Bluetooth Removal: 步骤 7 中的图像 3,3
    • Remove the 4 Phillips head screws belonging to the small bluetooth circuit board.
    • Using tweezers, remove the ribbon cable connection.
    • Set the bluetooth circuit board aside.
  8. iHome iBN97 Display Screen Replacement, Switch Board Removal: 步骤 8 中的图像 1,3 iHome iBN97 Display Screen Replacement, Switch Board Removal: 步骤 8 中的图像 2,3 iHome iBN97 Display Screen Replacement, Switch Board Removal: 步骤 8 中的图像 3,3
    • Remove the 9 Phillips screws that fasten the switch board to the unit.
    • Remove the switch board and place it outside of the unit, out of the way.
    • The switch board is attached by a flat ribbon cable to the logic board, which is tethered to the unit by a radio wire. It shouldn't get in the way, however.
  9. iHome iBN97 Display Screen Replacement, Dismantling the Case: 步骤 9 中的图像 1,3 iHome iBN97 Display Screen Replacement, Dismantling the Case: 步骤 9 中的图像 2,3 iHome iBN97 Display Screen Replacement, Dismantling the Case: 步骤 9 中的图像 3,3
    • If your screwdriver is small enough to fit inside the width of the case, this step is not necessary. Skip ahead to Step 11 and perform the step inside the case.
    • Using the size 1 Phillips screwdriver, remove the 4 Phillips head screws that hold the different parts of the case together.
  10. iHome iBN97 Display Screen Replacement, Screen Removal: 步骤 10 中的图像 1,3 iHome iBN97 Display Screen Replacement, Screen Removal: 步骤 10 中的图像 2,3 iHome iBN97 Display Screen Replacement, Screen Removal: 步骤 10 中的图像 3,3
    • Slide the screen up and out of the unit.
    • This part is attached in a tongue and groove fashion. It should come out without any snapping.
  11. iHome iBN97 Display Screen Replacement, Time Screen Display Removal: 步骤 11 中的图像 1,3 iHome iBN97 Display Screen Replacement, Time Screen Display Removal: 步骤 11 中的图像 2,3 iHome iBN97 Display Screen Replacement, Time Screen Display Removal: 步骤 11 中的图像 3,3
    • Remove the 8 Phillips screws and remove the time display screen.
    • These screws are size 2 again.
  12. iHome iBN97 Display Screen Replacement, Finished!: 步骤 12 中的图像 1,2 iHome iBN97 Display Screen Replacement, Finished!: 步骤 12 中的图像 2,2
    • Now this component is either repaired or replaced.
结论
Follow these steps backwards to reassemble the device. The reassembly is straightforward; it should all fit well again.
另外一个人完成了本指南。
Luke Williams
于09/29/15注册
500 声望
创作了2篇指南
团队
Cal Poly, Team 10-1, Green Fall 2015 Cal Poly, Team 10-1, Green Fall 2015 的会员
CPSU-GREEN-F15S10G1
4 名成员
创作了7篇指南
一条评论
Where did you find iHome iBN97 Display Screen Replacement?
Angelo Mastrella - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,170
