跳转到主内容
iHome iAVS16 LCD (Display) Replacement
你所需要的
  1. iHome iAVS16 LCD (Display) Replacement, Power Board: 步骤 1 中的图像 1,3 iHome iAVS16 LCD (Display) Replacement, Power Board: 步骤 1 中的图像 2,3 iHome iAVS16 LCD (Display) Replacement, Power Board: 步骤 1 中的图像 3,3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 LCD (Display) Replacement: 步骤 2 中的图像 1,3 iHome iAVS16 LCD (Display) Replacement: 步骤 2 中的图像 2,3 iHome iAVS16 LCD (Display) Replacement: 步骤 2 中的图像 3,3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 LCD (Display) Replacement: 步骤 3 中的图像 1,2 iHome iAVS16 LCD (Display) Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 LCD (Display) Replacement: 步骤 4 中的图像 1,3 iHome iAVS16 LCD (Display) Replacement: 步骤 4 中的图像 2,3 iHome iAVS16 LCD (Display) Replacement: 步骤 4 中的图像 3,3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 LCD (Display) Replacement, LCD (Display): 步骤 5 中的图像 1,3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): 步骤 5 中的图像 2,3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): 步骤 5 中的图像 3,3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 LCD (Display) Replacement: 步骤 6 中的图像 1,1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 LCD (Display) Replacement: 步骤 7 中的图像 1,3 iHome iAVS16 LCD (Display) Replacement: 步骤 7 中的图像 2,3 iHome iAVS16 LCD (Display) Replacement: 步骤 7 中的图像 3,3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
结论
Marco Sousa
于10/25/19注册
293 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G7
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 296
