跳转到主内容
iHome IBT16 Auxiliary Port Replacement
你所需要的
  1. iHome IBT16 Auxiliary Port Replacement, Base Plate: 步骤 1 中的图像 1,2 iHome IBT16 Auxiliary Port Replacement, Base Plate: 步骤 1 中的图像 2,2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome IBT16 Auxiliary Port Replacement: 步骤 2 中的图像 1,2 iHome IBT16 Auxiliary Port Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome IBT16 Auxiliary Port Replacement, Auxiliary Port: 步骤 3 中的图像 1,2 iHome IBT16 Auxiliary Port Replacement, Auxiliary Port: 步骤 3 中的图像 2,2
    • Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
    • Don't misplace the screws! Keep them in a safe place while working on the device
    • Make sure to ground yourself prior to continuing at this point
  4. iHome IBT16 Auxiliary Port Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, pull the motherboard out of the casing
    • Make sure to lift it out at an angle to the back, as the plastic power switch is attached to the board and can be broken
  5. iHome IBT16 Auxiliary Port Replacement: 步骤 5 中的图像 1,2 iHome IBT16 Auxiliary Port Replacement: 步骤 5 中的图像 2,2
    • Desolder the 5 points holding the auxiliary port to the motherboard
    • Once complete, it's as simple as lifting the port from the board
结论
Ryan Edwards
于03/21/17注册
331 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 568
