跳转到主内容
iHip Fold-up Portable Speaker Motherboard Replacement
你所需要的
  1. iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 iHip Fold-up Portable Speaker Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Place the device on a flat surface as shown.
    • Remove the battery case cover and batteries.
  2. iHip Fold-up Portable Speaker Motherboard Replacement: 步骤 2 中的图像 1,3 iHip Fold-up Portable Speaker Motherboard Replacement: 步骤 2 中的图像 2,3 iHip Fold-up Portable Speaker Motherboard Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using a Phillips-Head #1 screwdriver, unscrew the four outer 1.0 mm screws and remove with tweezers.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Remove the back cover carefully; there are many wires that connect it to the device.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  3. iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: 步骤 3 中的图像 1,2 iHip Fold-up Portable Speaker Motherboard Replacement, Unscrewing the Motherboard: 步骤 3 中的图像 2,2
    • Observe the location of the motherboard at the bottom center of the back cover.
    • Using a Phillips-Head #1 screwdriver, carefully unscrew all three 0.4 mm screws from the indicated locations. Set aside for reassembly.
    • Using tweezers, gently remove the motherboard from the back cover of the device.
  4. iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: 步骤 4 中的图像 1,2 iHip Fold-up Portable Speaker Motherboard Replacement, Cutting the Wires: 步骤 4 中的图像 2,2
    • Note the connection point of each wire to the motherboard.
    • Using utility scissors, cut all the wires connecting the motherboard to the device.
    • Using tweezers, place the new motherboard in the exact position of the old motherboard.
  5. iHip Fold-up Portable Speaker Motherboard Replacement, Soldering the Wires: 步骤 5 中的图像 1,1
    • Read the manufacturer instructions for your specific soldering iron before use. Follow all safety instructions and solder at your own risk.
    • Position a strip of solder at the point of contact between the motherboard and each individual wire.
    • Solder the wires to the motherboard. Make sure to follow the manufacturer's instructions, as well as general soldering safety principles.
  6. iHip Fold-up Portable Speaker Motherboard Replacement, Securing the New Motherboard: 步骤 6 中的图像 1,1
    • Using a Phillips-Head #1 screwdriver, screw the original 0.4 mm screws into the correct places to secure the motherboard back in place.
结论
Amanda
于10/13/14注册
201 声望
创作了2篇指南
团队
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G4
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 13
总计 608
