当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Your iFixit screwdriver has seen better days. Its been in one to many tight places and its mated with far too many screw faces. Its been a part of so many fixes that it seriously would appreciate some down time.
But no, you want to keep using this driver. You want it to weather the next fix. It's just not performing like it used to in its glory days.
So what is this anyway? A guide to fix a screwdriver? You bet.
这个步骤还没有翻译 帮忙翻译一下
If you're an owner of the original iFixit screwdriver included in the 54 Bit Driver Kit, you've probably noticed that the rubber grip rings on the screw driver wear out over time, develop small tears and fall off.
Regardless if they wear from over-torquing or the build up of oils from your hands, it's quite frustrating to lose the grip on a prised screwdriver.
这个步骤还没有翻译 帮忙翻译一下
So how do you remove the old grip? Simple, use your fingernails!
Otherwise, use toothpicks!
Remember the mohs scale? Wood won't carelessly scratch your metal tool!
4等其他人完成本指南。
一条评论
Worked like a charm.
Now all I need is to get instructions on how to assemble a replacement 54-bit driver kit case….
