跳转到主内容
iFixit Screwdriver Grip Replacement
你所需要的
  1. iFixit Screwdriver Grip Replacement, Grip: 步骤 1 中的图像 1,1
    • Your iFixit screwdriver has seen better days. Its been in one to many tight places and its mated with far too many screw faces. Its been a part of so many fixes that it seriously would appreciate some down time.
    • But no, you want to keep using this driver. You want it to weather the next fix. It's just not performing like it used to in its glory days.
    • So what is this anyway? A guide to fix a screwdriver? You bet.
  2. iFixit Screwdriver Grip Replacement: 步骤 2 中的图像 1,3 iFixit Screwdriver Grip Replacement: 步骤 2 中的图像 2,3 iFixit Screwdriver Grip Replacement: 步骤 2 中的图像 3,3
    • If you're an owner of the original iFixit screwdriver included in the 54 Bit Driver Kit, you've probably noticed that the rubber grip rings on the screw driver wear out over time, develop small tears and fall off.
    • Regardless if they wear from over-torquing or the build up of oils from your hands, it's quite frustrating to lose the grip on a prised screwdriver.
  3. iFixit Screwdriver Grip Replacement: 步骤 3 中的图像 1,2 iFixit Screwdriver Grip Replacement: 步骤 3 中的图像 2,2
    • Here's the solution: throw some o-rings on it.
    • 1/16in thick, 7/16 OD, 5/16 ID work wonders.
    • OD= outside diameter.
    • ID= inside diameter.
    • I picked up a bunch from my local hardware store. They are manufactured by Midwest Fastner. They cost $0.31 USD each.
  4. iFixit Screwdriver Grip Replacement: 步骤 4 中的图像 1,1
    • So how do you remove the old grip? Simple, use your fingernails!
    • Otherwise, use toothpicks!
    • Remember the mohs scale? Wood won't carelessly scratch your metal tool!
  5. iFixit Screwdriver Grip Replacement: 步骤 5 中的图像 1,2 iFixit Screwdriver Grip Replacement: 步骤 5 中的图像 2,2
    • That's it. If your grip's gone, shower your screwdriver in o-rings.
    • Enjoy that new, glistening rubber grip on your screwdriver.
结论
To reassemble your screwdriver, follow these instructions in reverse order.
4等其他人完成本指南。
Anthony Kouttron
于02/24/17注册
5,498 声望
创作了5篇指南
团队
salvagedcircuitry salvagedcircuitry 的会员
Business
1 名成员
创作了7篇指南
一条评论
Worked like a charm.
Now all I need is to get instructions on how to assemble a replacement 54-bit driver kit case….
Jason Higley - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 14
总计 1,862
