跳转到主内容
iFixit 26 Bit Driver Kit Technique for Removing Bits
你所需要的
  1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: 步骤 1 中的图像 1,1
    • Note how challenging it is to remove a required bit from the kit. Argh!
  2. iFixit 26 Bit Driver Kit Technique for Removing Bits: 步骤 2 中的图像 1,1
    • Find yourself a rubber band...
  3. iFixit 26 Bit Driver Kit Technique for Removing Bits: 步骤 3 中的图像 1,1
    • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
  4. iFixit 26 Bit Driver Kit Technique for Removing Bits: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
结论
48等其他人完成本指南。
aaronmiller
于08/28/11注册
1,376 声望
撰写一个指南
一条评论
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 60
总计 4,727
