跳转到主内容
iDevices iGrill Probe Replacement
你所需要的
  1. iDevices iGrill Probe Replacement, Probes: 步骤 1 中的图像 1,1
    • Remove the back plastic cover from the device; this should allow you access to the batteries.
  2. iDevices iGrill Probe Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the device.
  3. iDevices iGrill Probe Replacement: 步骤 3 中的图像 1,2 iDevices iGrill Probe Replacement: 步骤 3 中的图像 2,2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
    • Remove the accompanying plastic tabs under the screws.
    • Gently pull off the back cover from the device.
  4. iDevices iGrill Probe Replacement: 步骤 4 中的图像 1,3 iDevices iGrill Probe Replacement: 步骤 4 中的图像 2,3 iDevices iGrill Probe Replacement: 步骤 4 中的图像 3,3
    • If you have not removed the 2 silver-colored screws; you must remove them now.
    • Remove the metal terminals from the battery slot closest you.
    • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
    • Remove the internal cover.
  5. iDevices iGrill Probe Replacement: 步骤 5 中的图像 1,1
    • After the internal plastic case has been removed, you will have access to the probe contacts.
    • You should then insert the probes to check their connection to the probe terminals.
  6. iDevices iGrill Probe Replacement: 步骤 6 中的图像 1,1
    • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
结论
Michelle Nguyen
于02/16/16注册
204 声望
创作了2篇指南
团队
IUPUI, Team 3-4, Harley Spring 2016 IUPUI, Team 3-4, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S3G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,022
