跳转到主内容
iDevices iGrill Power Delivery Wires and Springs Replacement
你所需要的
  1. iDevices iGrill Power Delivery Wires and Springs Replacement, Power Delivery Wires and Springs: 步骤 1 中的图像 1,1
    • Place the front screen of the device on a flat surface, this allows access to the back cover. Remove the back cover from the device to access the batteries.
  2. iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries from the device, allowing you to access the screws necessary for removal of the back panel.
  3. iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 3 中的图像 1,2 iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 3 中的图像 2,2
    • Remove five black 10 mm Phillips #0 screws from the back side of the device.
    • Remove two silver-colored 5 mm Phillips screws from the left side of the internal cover.
  4. iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 4 中的图像 1,1
    • Gently and slowly pull the back cover off of the iGrill, exposing the power cables to the motherboard.
  5. iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 5 中的图像 1,2 iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 5 中的图像 2,2
    • Gently pull the metal terminals to the batteries out of their plastic holders.
    • Position the metal terminals such that you will be able to pull the plastic component that holds the batteries away from the motherboard.
    • Remove the internal cover from the device.
  6. iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 6 中的图像 1,1
    • After you have peeled back the rear plastic covering, you will have access to the motherboard.
  7. iDevices iGrill Power Delivery Wires and Springs Replacement: 步骤 7 中的图像 1,1
    • From here, you will have access to both the metal terminals of the power transfer wires and the soldering points of the power transfer wires to the motherboard.
    • If any of these connections have been broken, repair them with a solder and soldering wire.
结论
另外一个人完成了本指南。
Kyle McElyea
于02/16/16注册
259 声望
创作了2篇指南
团队
IUPUI, Team 3-4, Harley Spring 2016 IUPUI, Team 3-4, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S3G4
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 273
